Hello, my passenger power window is on it's way out. How difficult is it to replace? How much should I expect to spend and should I go to Napa or the dealer?
I need to throw new speakers in there while in at it, so might as well do it all at once.
The reason I ask is because I know the power windows in my 97 Camaro are a pain due to the fact that everything is riveted.
Thanks,
Steve
Not sure about a '99, but the Fords I've owned have all had bolt-mounted PW motors. Usually, you have to drill a hole to access one of the 3 bolts. Motors usually run about $50 at an auto parts store. To save some trouble, cut the electrical plug off your old motor before you exchange it, as the new ones usually don't come with that.
