I drilled 2 holes above that rear bracket to get a torx driver inI was having play on my gear shifter. I previously adjusted the gear select indicator so it would always start in park. Anyway, decided to tear into it a little more. Removed instrument cluster and found play in the the lower bushing on the gear shifter column. Getting up and down play and a little side to side in the gear shifter column at the bushing when I move the shifter slightly. Anyone ever replaced these without taking apart the whole dash more than I already have. I attached a photobucket pic. The bushing is in the center of the pic around the gear shifter column. Also, anyone know if I can start my truck with instrument panel unplugged? Not plan on driving it, just wanted to move it slightly. Thanks for any input, Part numbers would also be great if anyone has them handy.
bushing picture by galexander - Photobucket
You can adjust the meshload with the screw on top of the box, others have had good luck with that but when I tried it it just made the steering weird, hard spots, tight, etc. NAPA has rebuilt ones with a lifetime warranty for about $200 so I just changed it out. Hardest part is getting the pitman arm off.I ended up using a little rachet bit wrench. Look almost like a wrench but has the 1/4 inch for the bit. I ended up getting a thin plastic bushing and cutting it in half then put it over the existing busing. No more slop. Now if I can just figure how to get the annoying slop out of the steering box. People following me probably think I am a drunk driver. Has about one inch of slop in the steering wheel.
