folks,
i have now had my truck in to the dealer 2 times to try to solve intermittent surge at idle, and also excesive turbo "stalling, sputtering, coughing" at around 22lbs of boost, but they have once again told me that they cannot find anything wrong. the turbo issue is most concerning me, as it typically only happens when i am towing my 5er, and 22+lbs of boost is easy to hit for long periods of time (uphill). based on my previous experience of having the EBP replaced (a year ago), and from reading on this board, i am thinking i have some issue with either the EBP sensor, EGR valve, and the VGT solenoid -- or a combination of all three??
since the dealer cannot find the problem, i am probably just going to bite the bullet and buy the parts myself. so, is the EBP something that i can replace? not sure if there is some type of software calibration that needs to be done, or if this is a simple swap. if it is something that i can do, how difficult? any special tools? i would imagine that i would start there, since from what i understand the EGR functioning is dependent on info from the EBP.
so, after all this rambling, i guess i am looking to find out if this is something that i should even entertain on doing myself?
thanks.
thanks.
