1 - 13 of 13 Posts
The manual, if I read it right, says 2.0 quarts. I remember reading several times online 2.1 quarts is when it should start coming out the fill hole, so I only bought three... I just put in 3 quarts and it was all still going in when I finished.
Do I need more, to reach the fill hole? Am I fine? Too much?!
IIRC correctly mine took just over 3 to get to the bottom of the fill hole...I would keep on fillin till it comes outthe hole...i dont know what they were smokin when they wrote in 2 qts...
-Casey
/ubbthreads/images/graemlins/vomit.gif
Okay. I only bought 3 quarts of the stuff though, online. /ubbthreads/images/graemlins/frown.gif I'll see if I can find it (Redline D4 ATF) local, I haven't seen it though which is why I went online. I want to drive my truck and try out the fresh Redline MTL!
If it means anything, my driveway is sloped so the front is slightly downhill... probably not more than 6". Maybe that is enough to keep the level below the fill plug and higher in the front of the transfer case? Just wishful thinking... /ubbthreads/images/graemlins/grin.gif
Okay I should have checked the level too before freaking out.
It seems to be less than 1/4" from the fill hole. It's right about there... I guess I am fine. I got it all plugged back up and may go for a spin after dinner.
Yeah you are probably fine...let me know how you like that MTL...I did mine with it almost a year ago and i love the stuff.
-Casey
Yup I searched around a lot to see what I should run, and pretty much every other post I read was you "I put the MTL in my tranny and it rocks! blah blah blah /ubbthreads/images/graemlins/rolleyes.gif" so I figured I'd give it a shot. /ubbthreads/images/graemlins/grin.gif
I think it will work well. /ubbthreads/images/graemlins/smokin.gif
-Casey
[/ QUOTE ] What is it w/this MTL that you love so much, or what do you notice different, is'nt it just syn. lube?
-Casey
I was having a bit of grinding once in a while going into 3rd and 5th gears...Checked and replaced bushings accordingly...helped some but not completely.
Thats when I heard about MTL and how it helped smooth out a lot of guys ZF-5's. So being a little skeptical I tried it and boy it sure felt nice. Shifts really smooth any grinds are gone.
-Casey
So just to be sure cause I think there are 2 things going on here...the tranny takes MTL which is a popular change, but the transfer case takes automatic tranny fluid, at least that is my understanding. I don't remember reading about anyone putting MTL in the transfer case. Could be wrong though /ubbthreads/images/graemlins/shrug.gif.
...on research Redline recommends D4-ATF for replacement in units that require Dexron auto-tranny fluid..
Art
Discussion Starter · #10 ·
Wow, Casey... now there are two of us. That stuff rocks!
I wasn't having any grinding but it sure made shifting each gear a lot smoother. Second gear used to grind if I did it wrong/too fast, now it's takes like half the effort it did at worst to get into gear.
4 quarts through the shifter. /ubbthreads/images/graemlins/smokin.gif /ubbthreads/images/graemlins/smokin.gif /ubbthreads/images/graemlins/smokin.gif /ubbthreads/images/graemlins/smokin.gif
Right on glad you are having a good experience with it like I am. I have never heard of anyone putting MTL in their transfer case, just synthetic ATF. I did 4 qts. through my shifter too....but in my case I didn't have a choice..i broke 2 hardened sockets on my tranny fill plug before I gave up /ubbthreads/images/graemlins/crazy.gif
-Casey
-Casey
just so no one makes a costly mistake... in ryans post he said he is using redline in the transfer, he has already put the MTL in the tranny and he is antsy to run it, but not until he gets his transfer serviced... pardon me for any interuption.....
Discussion Starter · #13 ·
-Casey
Yup.
4 quarts of MTL went in the tranny, 3 quarts of ATF went in the t-case. I just drove 250 miles on it including a run down the drag strip and so far so good. /ubbthreads/images/graemlins/smokin.gif
I think I will still buy one more quart to make sure the transfer case is full, even if it means I only get one or two more ounces in (which is all I think it will take)... just to be sure.
1 - 13 of 13 Posts
