I found the codes to get coolant temp for my 7.3L out my Scangauge II xgauge:
TXD: C410F1221139
RXF: 046205110639
RXD: 3008
MTH: 00010002007F
Here's the catch, and why I don't think scanguage advertises the code: The signal changes resolution part way through the warm-up and the math can't be triggered to change with it. It's really simple tho, below 127F it reads 2x the temperature, so as the vehicle warms up the reading is double until it reaches 127F. I.e., during w/u the gauge will read up to 254, then when crosses 254 it will switch to actual temp and drop to reading to the "actual" 127F, after which it remains accurate.
I punched this one in this morning, and verified it works on my xgauge.
TXD: C410F1221139
RXF: 046205110639
RXD: 3008
MTH: 00010002007F
