O.K. Larry..... And I am not starting an argument here but I feel like the information you are providing might be wrong or maybe I should say (can you explain this). EVEN though some parts DO seem to hold up. There IS a reading in one of the factory set (ScanGauge2) positions that does indeed read as you say, (a -40 deg.), BUT how do you explain the readings I get when I put in the codes provided by 505live into one of the (x gauge) positions? They MUST be coolant temperature readings because they are completely independent numbers. They rise and fall just as you would expect to see the coolant numbers do. They vary from the oil temp. figure again, very much as you would expect coolant temps. to do. So just what is the ScanGauge2 picking up here? While it does not work perfectly as described above. Once it gets over the 254 degree (hump) it goes right to 127 degree reading at just about the amount of engine running time you would think it takes to get to 127 degrees, and continues to rise just
as if it had a physical probe sticking in the system somewhere. It's NOT oil, Transmission or air temp. So just what the heck is this gauge picking up from the OBD port, if as you say, the coolant temp. goes straight to the dash gauge and there is NO active information being sent through the OBD port or to the PCM? Oh, The 175 degree which IS lower than the factory 193 or 195 is probably (IMHO) because of one or two reasons. First, I hardly ever go far enough or hard enough to get up to full temp. and Second , and I think more likely, I probably have a thermostat that needs to be replaced because (and I am just guessing here because I am not a mechanic or engineer) The spring has probably weakened and is causing the stat. to open earlier. OR I might have it backwards depending on how these things are designed. The spring might get stiffer from (work hardening)(multiple times being heated & cooled) and causing the same problem......getting a stat. that opens at the wrong temperature. Hence my 175 or so high readings. Probably why I read that the stat (even the 203) should be changed every year or so. (Not that anyone does that) BUT it IS written up in the technical manuals AND on the dieselite.com site.
NOW, I very well might be completely WRONG (it will not be the first time) but I would like to hear from some other (EXPERTS) on this question to get a more (rounded) opinion as to about what this gauge is picking up using 505Live's provided codes.
Sure looks like coolant temps. to me. Thanks for your time DDT
