1 - 20 of 34 Posts
i would like to introduce myself first. i just bought my first diesel truck. its a 99 PSD, short box, ext cab, 4x4 with 90k on it. i'm still in iraq right now, so i've been buying allot of parts off of the net. so far i've bought a 4in turbo back, s&b intake, TS 6 position chip, gauges, propane, and water/meth kit, hpx line, pre-pump in tank kit. my goal is to eventually make 500 to 550hp. i was wondering what the best way to go about getting this much HP. i would like to do it one step at a time, since a military paycheck isn't the best. i know that i will have to get a hpop mod, regulated return, injectors, and a turbo. what would be the best order to do these mods? will i also have to put in head studs? i think that someday i would like to run nitrous, so i'm sure that i would have to get headstuds then. what else would i have to do to make sure that the motor doesn't turn into an expensive piece of scrap metal? i know that i've got allot to learn, so any advice would be great, thanks
Andy
500 without injectors or a turbo? i was thinking that with the stuff that i have now, i would be lucky to have 350. also anybody have any thoughts on a clutch? i imagine that the stock one will head south not long after all of this stuff is on. thanks
Andy
IF you spend enough money on your chip and tuning you could make a great ways up their, we had a duramax that was crazy HP's with a 4thousand dollar chip. The propane and other injection kit will add close to another 80 to 100...I would buy an aftermarket turbo though if you have the doe. I know ur in the army and dont have bills too pay most likely and are young which so am I but dont go stupid. My cousins and older brother are serving currently and all of them are waisting their money invest in something while you have a completely investable income. Not saying it wouldn't be awesome to have a kick butt diesel, but think about the future not playin around in ur truck lol.
Duramax is a whole different animal. It can do 500 with just easy parts like a chip, and intake and exhaust. By the way it doesn't take a 4 grand chip to make 500 in a dmax. With the mods that the above poster has he should have between 280 and 300. 500 will require injectors and a turbo at least. IMHO get the injectors first and have your chip retuned for them and be easy on it till you get the turbo. Then get a turbo that is pretty big like a modded H2E or bigger.
Personally I would sell the propane kit if my goal was 500 HP. Sure it will get you 80 to a 100 HP now but will have to go when you get the bigger injectors later. Plus you might get the temptation now to turn it up and bust something.
Then I would save a little more $$$ and get a dual HPOP set up first.
Now if you have an early 99 you would be ahead with a different turbo.
Dominator 66 or a H2 variant.
Then I think you will need mini-me or bigger injectors.
I was thinking about the hpop first. I've heard allot of really good things about it. mostly that it smoothes out the power, torque curve, and mpg. As far as a turbo, will the dominator make the 500 mark? I was looking at the sledgehammer, or a twin turbo setup(I like the bling factor). But if the dominator will make 500hp, thats allot of money that i could spend somewhere else. Thanks for the input
Ditch the LP.
Add:
Head studs
Big Oil
B Code injectors
H2E or QSSB Turbo
Good DP tuning
ITP Fuel system
Upgraded Trans. and cooler
Upgraded IC if towing heavy
Should be in the 500+ range.
550 with the hybrids and a single stock hpop.
[/ QUOTE ]wow thats impressive
how much could i get with B codes, big oil, and a modded he2?
Probably more than your stock forged rods can handle.
isnt theat the purpose for hybrids...i was helping a buddy mod his ven.....cslled jody...he sudgester slass 5 hybrids and an h2e.....now i halfto put my dp on the 80 setting to stay ahead of him...and he dosent even have a chip yet...no big oil and he dosent throw codes......so dosent that mean hybreds are a way around big oil ?????
You can get right a 500 and just a little over on stock oil with A codes. And hybrids with big nozzles will probably be more then your rods can handle.
1 - 20 of 34 Posts
