1 - 11 of 11 Posts
Re: How to read vin/door code
what code is listed on the tag for your axle?
vin won't help with axles, for reference here's what vin tells you. hth
1, 2, 3rd digits = world manufacturer identifier (in my case, made in us and it's a ford pickup)
4th = brake type
5, 6, 7th = line, series body type (ex: f250, xl, superduty)
8th = engine
9th = check digit, doesn't tell you anything
10 = model year
11= assy plant
12-17 = production sequence
Don't know i will craw under there tonight and look for one. Any hints where is it at. /ubbthreads/images/graemlins/shrug.gif
It is a tag on one of the bolts for the differential cover.
You don't help us answer your questions because you haven't filled out your signature with detailed info about your pickup.
By hook or crook, I learned you have a "99 F250 4wd 7.3 with a manual trans".
All 99 F250 7.3 with either trans have a Ford/Visteon "Sterling" rear axle with 10.5" ring gear and 3.73 axle ratio. So the only question is whether you have LS or not.
The axle code on the Federal Certification Label on the lower doorpost behind the driver's door will begin with either a number or a letter. If it begins with a number, you have an open axle. If it begins with a letter, you have LS.
For example, mine is "C1", so I have LS. If yours is 31, you have an open axle.
My door code reads Axle:RC24; ...
No, you're looking up instead of down. The axle code is under the word "Axle".
Mine has "RC 52" above and slightly to the right of the word "Axle", but the RC code has nothing to do with the axle. RC is short for "region code", but that's the end of my knowledge. /ubbthreads/images/graemlins/blush.gif
'99 through '04 F-250 PSD axle codes will be 31 or C1. 31 is open axle and C1 is limited slip.
All 99 F250 4wd 7.3 with either trans has a Ford/Visteon "Sterling" rear axle with 10.5" ring gear and 3.73 axle ratio. So the only question is whether you have LS or not.
Pretty slick, took me a while to figure it out. And that was after reading your post.
Thanks for the lesson Detective Smokey
You gotta watch those old guys, sneaky as all get out /ubbthreads/images/graemlins/biggrin.gif
The following lists the gear ratios on rear axles.
31 - 3.73 non-limited slip, F-250/Excursion
C1 - 3.73 limited slip, F-250/Excursion
32 - 4.10 non-limited slip, F-250
C2 - 4.10 limited slip, F-250/Excursion
33 - 4.30 non-limited slip, F-250
C3 - 4.30 limited slip, F-250/Excursion
36 - 4.56 non-limited slip, F-250
C6 - 4.56 limited slip, F-250
41 - 3.73 non-limited slip, F-350 (single rear wheels)
D1 - 3.73 limited slip, F-350 (single rear wheels)
42 - 4.10 non-limited slip, F-350 (single rear wheels)
D2 - 4.10 limited slip, F-350 (single rear wheels)
43 - 4.30 non-limited slip, F-350 (single rear wheels)
D3 - 4.30 limited slip, F-350 (single rear wheels)
46 - 4.56 non-limited slip, F-350 (single rear wheels)
D6 - 4.56 limited slip, F-350 (single rear wheels)
F1 - 3.73 limited slip, F-350 (dual rear wheels)
62 - 4.10 non-limited slip, F-350 (dual rear wheels)
63 - 4.30 non-limited slip, F-350 (dual rear wheels)
66 - 4.56 non-limited slip, F-350 (dual rear wheels)
F6 - 4.56 limited slip, F-350 (dual rear wheels)
81 - 3.73 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E1 - 3.73 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
82 - 4.10 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E2 - 4.10 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
83 - 4.30 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E3 - 4.30 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
86 - 4.56 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E6 - 4.56 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
88 - 4.88 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
EW - 4.88 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
G3 - 4.30 limited slip, F-450 Chassis Cab
73 - 4.30 non-limited slip, F-450 Chassis Cab
78 - 4.88 non-limited slip, F-450 Chassis Cab
G8 - 4.88 limited slip, F-450 Chassis Cab
75 - 5.38 non-limited slip, F-450 Chassis Cab
G5 - 5.38 limited slip, F-450 Chassis Cab
GW - 4.l0 limited slip, F-450 Chassis Cab
98 - 4.88 non-limited slip, F-550 Chassis Cab
K8 - 4.88 limited slip, F-550 Chassis Cab
95 - 5.38 non-limited slip, F-550 Chassis Cab
K5 - 5.38 limited slip, F-550 Chassis Cab
KW - 4.10 limited slip, F-550 Chassis Cab
75 - Dana 80, F53 Recreational Stripped Chassis (Motorhome)
95 - Dana 135, F53 Recreational Stripped Chassis (Motorhome)
1 - 11 of 11 Posts
