I am needing some help trying to figure out how to replace the junk inside the steering column that works the ignition switch. I have the steering wheel off, the top and bottom covers, the key cylinder assembly out, and the gear and top rod (plastic) pulled out. I can't figure out how to get the lower parts out of the column and this is where it is broken as everything else appears to be okay. What connects the top parts to the bottom? There is a hole in the end of the top plastic piece. Is this supposed to be connected to a rod or what? What do you call this stuff? Help!!!! /ubbthreads/images/graemlins/shrug.gif
