Another question from a new guy. I have a 1993, 4x4, F-250 7.3 E40D trans. How do I keep my truck from up shifting to early in the upper gears 3-4-5. 1 into 2 seems ok and shifts around 3000 RPM's. Then the next shift comes in around 1800 RPM and lugs the engine, and the next one also. When I'm in overdrive and at cruising speed and push the off button it shifts fine up and down. It's just when I'm moving from a dead stop it shifts to quick into or missing the 3rd gears...Could I be missing and skipping over a third gear? I believe with the off button It is shifting 3 times, should there be 4 shifts? It could be I need educated on how to use the shift button???
