1 - 8 of 8 Posts
does anyone know how to tell a diesel zf from a gasser? Is there a different part number on the tag or some distinct feature that i can look at? Or does some one have measurements on the bellhousing bolt pattern ?
thanks
Only way I know how is the gasser versions have a taller 1st gear.
If you measure from the bottom bell bolt to the top bolt on the same side it is a greater distance on a diesel.I'll check it for you,I think it's about 13" on a diesel.I'll get back to you.
Doug
Hey thanks. I found a zf. i just want to make sure it is a diesel one.Maybe even a sketch w some measurement? All i have are BB gaser trans stuff
Thanks. that helped w some of my questions w the differences between the 42 and 47. I just need to find out what part numbers are on the case to see if gas or diesel
1 - 8 of 8 Posts
