1 - 8 of 8 Posts
Hi all
I have a leak. It looks like it is coming from the hp oil line fitting on the pasenger side head. Fitting to block that is.
I am working in camp and using the truck every day
So the questions are
1 how much worse can the leak get? can I get by with just adding oil for the next 30 days or am I looking at a sudden flood from this
2 what size is this o ring if I know I can get one picked up in town and shipped to me
Is it the o ring? Usually it just comes loose and the ring is fine. Just tighten. You can get the o ring, but I can't remember the size. I have a bunch. Were is camp? I'm in BC.
Thanks I will try to tighten the fitting tommorow.
Home is Hudson's Hope and I am presently working an hour out of Grande Cache Ab.
I had one leak for years. I just couldn't track it down to that.
Might find one at a parts/hydraulic shop that fits.
The o-ring size is either -905 or -906 (can't remember which). Should be available at a hydraulics shop. If the o-ring is split, the leak won't stop by tightening the fitting (but it will slow it down). If you can get the o-rings (buy a couple of each size), it's a pretty easy fix.
Found the info on o-ring sizes here: http://www.thedieselstop.com/forums/f47/o-ring-sizes-can-we-get-sticky-182977/
thanks again I tightened it today hopefully it will slow down a bit.
Heck if oil keeps going down I may never fix it LOL.
I would rather not take it apart untill i get home, Just my superstion
but things can get worse with no easy way to deal with it.
I think in the spring as preventitve maintance I will change over to CNC Fabs lines and do all the orings
The cnc lines comes necessary hardware and Orings
1 - 8 of 8 Posts
