**This kit contains:
http://www.dieselorings.com/8-002ex-extended-hpop-o-ring-reseal-kit-with-complete-hose-fitting-repair-kit.html
1. The O-ring that seals the IPR to the HPOP.
2. IPR internal seal O-ring and split washer (full IPR reseal kit).
3. The O-ring needed for the fill plug at the top of the reservoir.
4. TWO O-rings for the inside of the high pressure hose connectors that seal the hose to the pump.
5. TWO O-rings for the HPOP fitting threads.
6. TWO interior hose fitting PTFE backup spacer rings.
7. TWO hose fittings stainless steel hose locking rings.
8. O-ring for the Black bypass nut (top front of the pump)
9. O-ring for the pressure port plug on the passenger's side front of the pump.
10. Packet of LocTite 680 to seal the hose fittings and rear plug in the pump.
** High Pressure Oil Pump Gasket 94.5-03
http://www.dieselorings.com/hpop-engine-mounting-gasket-96-03.html
** Replacement "non-serviceable" Long Threaded Plug
http://www.dieselorings.com/serviceable-replacement-hpop-plug.html
** This complete 11 Viton o-ring reseal kit contains: WILL THIS WORK ON A F-650 TOO?!?
http://www.dieselorings.com/fuel-bowl-reseal-kit-1999-2003.html
3 Viton (type A) or 3 Viton (type B) or 2 Fluorosilicone plus 1 Viton o-rings for the 7.3 yellow fuel drain valve.
2 o-rings for the Water-in-Fuel sensor/Fuel Heater
1 o-ring for the Fuel Pressure Regulator housing
1 o-ring for the regulator piston bushing
2 o-rings for the fuel back check piston assembly
2 o-rings for bowl plugs
2 - 1/4" sleeves for the fuel lines feeding the cylinder heads
1 - 5/16" sleeve for the fuel return line
1 - 3/8" sleeve for the fuel feed line.
Will this pretty much give me everything I will need? As I have said I just want to replace everything as it is my daily driver and can't remove it unless I am ready to fix it.
