Has anyone fixed their HPOP that leaks down by replacing the quick fill check valve parts? I've read several posts that mention this or a worn front cover as a cause for no-start after sitting overnight (usually when it's cold out). I read that some have fixed the problem with a new front cover, but was wondering if others have been able to get by with just the check valve replacement.
Most of the time its torn injector o rings ,,did it come on suddenly ?..Maybe after a hard run ?...
No, it's been doing this for a year or more. Just replaced all injectors a few weeks ago to fix my cold/no start problem.
I can be the other things as well
The Check valve is in this pic ...
Auto part Automotive engine part Diagram Line art Automotive super charger part
hopfully it is not the front cover...
