I have a 99 psd just had all injectors, glowplugs,valve covers, and harnesses replaced by ford due to hard start and rough idle when cold. The truck has a hard time starting after sitting all night and the hpop is low. where is the oil leaking to, there are not external leaks.
WOW,, you had all that work done at FORD and can still afford internet service? :lol: There is a check ball in the reservoir IIRC and sometimes it can let oil bleed back down into the pan, That would be your hard start issue if it has been there all along,, sounds like you didn't need all that other work.:icon_rolleyes:
