Hpop on 1995 f-350 7.3 turbo
1.8K views 3 replies 4 participants last post by  Strokin36
#1 ·
I replaced the hpop gaskets and seals on my 95 7.3 turbo but now it will not start I need some ideas cause the tachometer does jump while turning it over and when I unplug the plug on the driver side valve cover the check engine light come on but still does not hit a lick
#2 ·
If you have a dry high pressure oil system it is going to take quite a while to start the truck. And even once it starts it won't run that well until you get all the air out of the high pressure oil system.
Crank for a while and let the starter rest. While it is resting check the oil level in the HPOP reservoir and top off if needed. A battery charger on the batteries will also help keeping them topped off.
#3 ·
Definitely keep your batteries on a charger while you are cranking multiple times...it takes a while.
