Guys, Can anyone give me the dimension of the height of both steps on the special seal installation tool? The bottom one that sets the seal depth on the axle shaft and the upper one that sets the depth on the installed knuckle seal. I am also looking for the thickness of the thrust washer that goes between the axle and hub. Thank You
I made the seal driver out of 1 1/4" pipe 12" long with a cap on one end and with a floor flange on the other ground down around the edges to fit the inside part of the seal. As far as depth I pounded it all the way to the collar of the axle shaft.
