I hadn't run the old 6.9 in a while, so ran it down for a fill up. It was running a bit off, so I took a gander at the IP. It was way off the marks, so I set it back. It seems to be running better now.
I need to start pulling a larger trailer, so have been looking at the Hypermax. They are claiming a 50% increase in power. I will be pulling freeway, and mountains, so the non-wastegated turbo sounds like the way to go. I'm not interested in acceleration.
Has anyone got before and after dyno or G-Tech information on the Hypermax?
If I order this part, I'll order a fresh IP from Oregon Fuel Injection set up for the Hypermax. I've got around 8-10K on a fresh set of injectors and head gaskets. The engine seems to be happy, but it doesn't make enough power to pull the passes with my one car trailer loaded, much less the two car trailer I need.
Is this a pipe dream? Should I just trade the old IDI in and get a Power-Stroke?
The last trip I took, the C6 emptied itself pulling the pass. I had to refill the transmission to complete the trip. It hasn't leaked a drop since. Weird.
I'm thinking the fluid got hot and blew out the front seal. The Low band doesn't seem to be holding like it used to. It feels a bit slippery till I stand in it.
It might be time to go through the C6 as well.
CJ
CJ
