I have a 2000 F350 Super Duty 4x4 dually with a 7.3 liter diesel and was changing out the four marker lights on the rear fenders with new LED lights. While changing out the fourth and last marker light, I turned the lights on to check the connection and the light came on. Without turning the lights off, I crimped the connections and taped them up. That's when I noticed that all four marker lights had went out. All the other lights inside and out worked fine. I checked the fusebox and found no blown fuses. So for general purposes, I changed out all the fuses with brand new ones under the dash. A little while later I noticed that I had no power windows, tail lights, map lights, glove box light, and under Hood light. I replaced the power window fuse but still no power windows. Any help would be appreciated. Thank you for your help! JUKEBOX65
