1 - 20 of 26 Posts
I have been searching all over the net for someone who makes and or sells good quality headstuds and gaskets. I own a 2004 XLT lariat 6.0 with 15,000 miles on it and after running the SCT tuner it started to puke (Blow cooant) all over the place. From what I have read on other sites and here I need to trash the stock bolts and replace with head studs. I have looked for ARP headstuds but can't seem to find them for my Powerstroke. Any input would be appreciated thanks.
I got some info on some studs, in a VM last night. I will look into it and let you know.
We have H-11 head studs coming. Should be about 2 weeks more.
Tadd
We recently sold our last set, but we have a shipment from ARP arriving in 3 weeks. It seems a lot more work went into the studs than ARP intended, so the price has been increased. I was selling the original's for about half the price that they are retailing for now.
ARP's head studs will ship in 2 weeks. I ordered a set. The part number is 250-4202. You can order from ARP, but their pricing is only good to their dealers. Direct was $530.42 for a set. I got mine from Summit (330-630-0270) for $380.69. I added 2nd day air, and my total cost will be $399.59. Ask for Mike in Sales. The part number is new and some people give up once they can't find it in their system. Mike has it in his. Price is right.
RL
ps, I am interested in anyone else's experience ordering these. Please post if you do.
Silly question but you haven't mentioned if you have anything installed but the SCT Tune, Do you have an upgraded exhaust and free flowing clean air system in place to reduce EGTs? If some coolant pukes from the reservoir people on here seem to be looking immediately at head studs. I have tried to look at all of the puke related posts but have yet to see anyone mention the fact that you have an EGR cooler being cooled by the coolant and that the pressurized system only increases the boiling point so high before the mix will boil. If we see EGTs in the neighborhood of 1500 degrees in some instances, has anyone thought that the problem might be flash boiling the coolant in the system? The EGR is in place to reduce oxides of nitrogen which create that nice brown haze in the atmosphere. Oxides of nitrogen develope when cylinder temps reach 2300 degrees F. So we have 2300 in the cylinder at least and then it gets to the egr system before the turbo and its sometimes 1500 at the turbo. Crazy thought but does anyone think that the cooling system which is in the 200+ degree range can handle 1000+ coming at it? But no it must be that Ford underdesigned the truck because it can't take somebody installing a tuner or a box with occasionally propane on top of that trying to roast 39" tires which is by my math a little over an extra 8.5" in diameter compared with stock wheels and tires. It only makes me smile when someone says their truck only pukes when they have the "instane" or any tune in regardless, and it goes away when the tuner is removed and the newest engineer(someone who buys a PSD and a intake/exhaust/tuner package and posts to say they can't believe the dealer won't warranty their engine) says they must have a damaged head gasket cause thats what happend to their truck. I used to think that if a head gasket was damaged that it was damaged but nowadays its an intermittant problem. The problem couldn't be the overtaxing of the egr cooling system trying to remove the excess heat in the exhaust. The stock trucks are doing it too, does this mean the head gaskets are bad? Maybe they are, but from what I have seen is that even the stock trucks are towing something and its usually 40 feet long. Yes the max that a trailer can weigh is 19.2k but only if its being pulled by a regular cab 4x2 f-350 with 4.10s. If the truck is bigger and has a lower gear ratio numerically then the wieght drops to 15.6k on a cc drw 4x4 350 with 3.73s. Ah yes the question will arise that someones trailer only weighs 10k and how come it still pukes stock? There are a million different variables to each situation such as grade of road in percent not if its paved gravel or other, speed at which this feat of weight movement is being accomplished, ambient air temp, condition of oil, air filter condition, automatic or manual trans, etc. It may be in the range of towable but at what speed and what condition? 60 up a mountain? I guess I went on a little rant, maybe im just tired of hearing Ford built it wrong. I now leave myself open to ridicule.
I have puked once while towing up a grade with the SCT in the tow mode(lowest setting). My EGTs were at 1200 and boost around 30. I was also using tow/haul at the time. Lesson learned after that...I will only use tow/haul mode while towing in city traffic or on down grades. After I stopped using it my temps went down and mileage went up by 3mpg and no more puking. This was towing approx 7K. 19' toy hauler, no fluids, a 500lb quad and gear. probably wasn't even 7K since the claimed dry weight of the trailer is 4500lb.
Good food for thought! Thanks. /ubbthreads/images/graemlins/vulnerable.gif
I agree with many of your comments but..
Many people have tried to fix this by plugging the EGR cooler and on many trucks it didn't fix anything. On my truck I had 4000 miles when it started to blow coolant with the Diablo or with the Edge and SCMT. It eventually got worse until I replaced the head bolts and gaskets with stock replacements. The puking was gone for about 5K miles. I never touched the EGR cooler. So I have to believe that Head gaskets were the cause, actually stretched head bolts. The puking has now returned and I know that I need stronger head bolts. The reason we went with H-11 studs instead of buying them from ARP is because I am going to put our big turbo on my 6.0 and ARP's have been known to stretch when boost gets up to 50 psi. (Just ask the Dodge guys).
Now I entirely agree about expecting Ford to warranty all this performance.
The reason the coolant stops is because the gasket is an MLS style. The layers separate enough to lose pressure and when the pressure comes down they reseal.
Tadd
I mentioned this before in another thread. You can test for compression gases in your coolant. If they are there then there is a good chance you have a head gasket/head bolt issue/failure. It could also be a leaking EGR valve.
I think there is some issue with these headbolts and the head gaskets too. /ubbthreads/images/graemlins/vomit.gif If the rumors are correct then we will see a recall of sorts soon.
There is little doubt that chipping these trucks is as certain a guarantee that you will puke. /ubbthreads/images/graemlins/phoney.gif
Very Hard to get the Gases in the Tank"We tried"5/5 100% meth" and Finally" but the Abuse hurt another ATS Transmission!!!!!! /ubbthreads/images/graemlins/frown.gifThankFully Clint is working with me and we have another Trans with His New Co-Pilot going in to help This one LAST!!!!!Tadd I want a Big Turbo Too when You Do My Truck also!!!!I want to be JUST LIKE YOU!!!!!! /ubbthreads/images/graemlins/smokin.gif
Just for grins have you measured fan speed on your truck before, during, and after a puking event?
I recently had a problem were a hyd fan on CAT machine was stopping during operation. The coolant recovery tank couldn't vent the explosion of steam and coolant and blew up. At full load this interuption of fan speed lasted no longer than 1 minute but that was enough to puke a gallon and a half of coolant. Just a thought with the electonic fan and all.
Here are a couple of SPY Photo's /ubbthreads/images/graemlins/wink.gif
Aurora 5000 Turbo
spy photos don't work. /ubbthreads/images/graemlins/blush.gif/ubbthreads/images/graemlins/shocked.gif /ubbthreads/images/graemlins/biggrin.gif
Should be good now /ubbthreads/images/graemlins/phoney.gif
much better /ubbthreads/images/graemlins/biggrin.gif. That thing looks a lot bigger than the factory one. /ubbthreads/images/graemlins/shocked.gif
Are there specs on it? Like, what pressures can it generate? Is it capable of higher flow rates? Is it variable vane or waste gate? Cost? Will it whistle? I am interested....
RL
1 - 20 of 26 Posts
