I need help
58 views 2 replies 2 participants last post by  jansen0987
#1 ·
How does this red ring come? I assume you pull it straight up and out but there is no real good place to grab on to or pry from
#2 ·
A little different plug when I was working on my 2008 tow mirrors:
Look on the back side, where wires are, and see if there isn’t a catch (clip) to release and push in on it like in this picture:
Then when it start to pop out you can grip it with needle nose pliers and remove:
And a look at the individual plastic clips, once that blade is out, and how they lock the pins in place:
Reactions: jansen0987
#3 ·
That is kind of what I ended up doing. I had to take the back cap and seal out and was able to
i was able to see just the ends of the red center pieces but it worked
