1 - 13 of 13 Posts
Well got the IC pipes fab'd up and installed. Turned out to be easy. I say that because I found a parts store that sells mandrel bent exhaust tubes. /ubbthreads/images/graemlins/smokin.gif /ubbthreads/images/graemlins/smokin.gif /ubbthreads/images/graemlins/smokin.gif /ubbthreads/images/graemlins/smokin.gif
Here's a pic:
http://home.austin.rr.com/jkmr/icpipes.jpg
The passengers side took 3 90 degree pipe and the drivers took 2 90s and 1 45 degree pipes.
Initial drive'n around the corner was fun. Lost about 3psi boost. Cool down after some hot rod'n was faster. When I did a run from 0 to 75, it looked like she ran about 150 degrees cooler.
The real test with a full load. I will let y'all know.
If I had to do it over again, I would because I am a hopeless gearhead that can not leave anything alone. Y'all know what I mean. /ubbthreads/images/graemlins/biggrin.gif
Later,
That looks great as you said it is definetely work all the work involved! /ubbthreads/images/graemlins/grin.gif
Justin
That looks really good. /ubbthreads/images/graemlins/smokin.gif
Very nice work, wish my fabrication skills were as sharp.
Looks great, If I can't get ahold of gts I might have to commission someone to build me a set of pipes.
Alan
LOL, I know that all to well /ubbthreads/images/graemlins/biggrin.gif
Nice job on the pipes /ubbthreads/images/graemlins/smokin.gif
Can anyone who has fabbed up their own pipes comment on the bend radius of the mandrel-bent 90's & 45's (long, short, exact number)? Thanks & Cheers!
Hi Pat,
You will need to fab 3 90s on the passenger side and 2 90s and 1 45 on the driver's side.
Buy 2 Js, 1 90, and 1 45. One J can be cut to make 2 90s. That will save you $30 (15 a piece).
I can not really comment on the radius, I just cut, fit, cut, fit, cut, fit, ...
HTH,
Jeff, congrats on the ic install, nice work /ubbthreads/images/graemlins/smokin.gif Do you still have the stock 1.15 exhaust housing on your turbo? Before I got injectors I had to use a 1.0 to get rid of the lag and gain my boost back. I guess by doing them yourself you just justifed the cost of your chop saw and welder /ubbthreads/images/graemlins/grin.gif What did you do on the sway bar?
Discussion Starter · #10 ·
Thank you.
It would of been harder without your writeup. /ubbthreads/images/graemlins/smokin.gif
Yea, it still have stock housing with a BD exhaust brake on it. I can still throw 20psi. I am going to get me a Tony 4-pos chip when I get back from my trip this week. Maybe in performance mode, I can gain some boost back.
I lowered my sway bar 3". That still gave me over an inch of clearence.
Here is the other pics from phase 1:
Big pic: http://home.austin.rr.com/jkmr/ic02.jpg
Put back together: http://home.austin.rr.com/jkmr/icfront.jpg
Nice Job Jeff!!!
You did yourself proud! Smart to have painted those pipes before you installed them... I learned the hard way that unpainted aluminized exhaust tubing still gets surface rust. Last time I had them out I cleaned them up and painted them in Ford engine gray.
Patrick,
When I was purchasing the mandrel-bent tubing, I found the J-bends to have a tigher radius than the U-bends. I cut the J-bend into two 90's and used them at the inlet and outlets of the I/C as there wasn't enough room to make a lazier bend upward. If there was enough room I would have used the gentler bends in all places. Hope that answers your question!
TC
Jeff & Tim, thanks for the replies! I've got the I/C up in the attic and a new little MIG welder (just a Lincoln SP-135T), just need the time to play. Cheers!
1 - 13 of 13 Posts
