I have a crank no start condition.
Replaced Fuel Pump and CPS. No Start.
Disconnected the wire from the ICP to see if it would start. It did not. But the disconnect causes Code P1280 which is an ICP low condition so I think this is a no start condition. If I connect the wire back up I can clear the code and does not show up again unless I disconnect.
So I am confused......After many searches disconnecting the ICP is standard in troubleshooting. But if my 2002 trows this code.....how could it start.
I am missing something here. Appreciate any help
(One more thing is I think I will replace it since I have oil present in the connecter)
