Recently the truck started acting funny while I drive. It feels like it is the ICP again. Is there anything that could cause and ICP to go bad because this will be the 3rd or 4th one that I have tried in a year.The second one was used but it was working fine when it was taken out of the truck. I do not have the 10K mod or anything like that in it so I am going nuts trying to figure out why these things keep going bad. Anyone have any ideas?
what are the symptoms? are there any codes? could ahve something to do with the IPR sticking. dont rule anything out.
Dan
· Banned
Are you sure that is the problem? If you have replaced that many it sounds like you may have problems elsewhere. Did you ever have a 10K in it? If so check your pins in the connector and make sure they have not be spread out wich would cause a bad contact on the sensor. I have seen that on a couple of occasions.
I tried the 10K once but I couldn't get it to work so I haven't messed with it anymore. I will check the pins but do you have any other ideas?
· Banned
I would check those pins then. If you had it in and took it out most likely they are spread apart and are not getting a good contact all the time.
