1993 idi ats turbo do I have to buy a return line repair kit to fix a leaky line or can I just buy 5/16 fuel line ? Does it have to be high pressure hose or will standard hose work? Is the fuel hose specific to diesel or will standard gas line work ? Any help appreciated
your better off to buy a return line kit from a diesel shop or on line like Pennsacola Diesel it includes the lines (you need), the caps ( you'll probably need cause they usually break trying to replace them) and the o-rings you"ll need cause they usually go bad or start leaking if you bump the caps ( if they've been on a awhile ). the kit typically goes for around $30.00.
Napa also has a return line kit with the newer caps, proper hose and the clamps it was about $100 cdn when I bought it and they had it in the store.
the pensacola kit will leak ina few months, they use cheap hose, the kits i use/provide german made hose that holds up for years. mine have 100k on them.
You need lines rated for Diesel fuel, gas hoses will not work as the diesel will soften and dissolve the hoses.
