Hi All,
Can I run a IDM 100 in place of an IDM 120 for a while till a new 120 gets here?
My late 99 F-350 took a dive last Sat morning, serious loss of power, missing, sputtering, smoking, grasping for life I had it limp me back home seldom faster than 10 MPH and inches per hour on slopes but it made it home then promptly died with a no start other than starting fluid for seconds at a time.
Scanned it with AE did my home work and felt IDM was best start point so I took the one out of my 97 F-350 and swapped it and now the 99 starts and runs. Have not driven it just ran it about 3 minutes.
If it runs and starts on the 100 it won't hurt anything. I believe the 100 is 100 volts to the injectors, likewise 120 is 120 volts.
· Administrator
You could leave the IDM-100 in forever without hurting anything.
I have one in my truck, although it's been modded to put out around 145V.
I've scimmed across the 145 volt mod, any bad long term effects?
I ordered a re-man XC3F-12B599-AC IDM 120 from Ecudiesel for $149 with lifetime warranty once I sent my dead one back.
I have 3 injectors showing bad in buzz test and they do sound different when they get buzzed.
Could this be the IDM doing this? Truck ran fine before this whole incident and it all went bad within about 30 seconds, hard to believe all 3 died at once.
truck never had a miss before last Saturday morning but has bad miss now with the IDM-100
holes 1, 7, 6 are showing "High to Low side short" in buzz test with AE
In cylinder contribution test hole 1 shows "Injector Circuit Contribution / balance fault"
the injectors are old, maybe original with 310,000 on the truck now.
looking at DP stock reman or maybe stage 1 reman, either way it's getting chipped. I never chipped it before because I knew the injectors were old.
· Administrator
No long term effects from the IDM mod. It's been around just about forever. Not a mod that you will feel in the seat of your pants, but it supposedly improves performance a bit. I haven't tested that on my truck.
Did you do a buzz test with the other IDM in place and did you get the same results? Until you get a clean buzz test, the cylinder contribution test doesn't mean anything, so disregard that for now.
Your original IDM may be just fine. Have you looked at the wiring harness where it goes over the driver's side valve cover? They put the injector circuit wiring on the bottom of the bundle, so the high voltage circuits would be the first to chafe and short against the valve cover.
With your mileage, your injectors may just be done in.
Truck was a No Start with the old IDM.
AE said "PCM/IDM Communications Error" and could not do the buzz test.
Yes I did have some wire chafing on 3 wires but only one was through just a tiny bit but I'm sure it was enough to ground, valve cover was clean there and paint rubbed off from wires so nothing was stopping it from grounding.
Not going to worry much about it until the new IDM gets here since the truck I took the IDM out (97) of hasn't been running real well.
But as I said this 99 was running perfect until it all went to hell in less than a mile. So not sure whats up with the injectors unless this episode killed the IDM and 3 injectors.
It was the ORANGE wire that had rubbed through.
Posted pics in a new thread for the wire chafing
http://www.thedieselstop.com/forums/f24/99-idm-wire-chafing-valve-cover-289005/#post2107546
Injectors have been on the to-do list for a while now just was waiting till they crapped out.
