2007 6.0L
Drove the truck ~ 20 minutes away to the gym, went back outside 1.5 hour later, everything worked but the starter didn't engage. No click, nothing.
I checked ALL the fuses that sound like they might relate, then swapped in the Blower motor relay. Tried to start in neutral and wiggled the gear shift around while in neutral and park. Still nothing.
Is this the Ignition Switch? Or what other things should I look at? I thought I just saw a thread where someone had posted a replacement DIY or diagram for the switch?
I got the truck home by turning the key to the Run position and then quickly crawling under the truck and jumping the posts on the starter with the spair tire lock thing from my glove box.
