I have 6.4 starters on 3 of our 4 trucks. They turn the 6.0s over very well. Also, I buy then from DB Electric and they are only about $80-90 each. Cheaper than the 6.0 starter at the parts house.
Makes sense, thanksDeep cycle batteries are for stuff like trolling motors, etc. not for starting engines. They are for long load cycles and are constructed differently than a starting battery. Running a starter motor for the few seconds it takes for cranking an engine is nowhere near a "deep cycle".
BTW, AGM batteries are not necessarily deep cycle. They come in deep cycle AND starting load types. Click on Compare the Differences Between REDTOP® vs. YELLOWTOP® vs. BLUETOP® Batteries.
I was actually thinking of the OPTIMAs when I posted. Some people on the various forums have posted that they have used the Deep Cycle Optimas and said they liked them. That said, I agree with you and the deep cycle battery is not the appropriate choice.Deep cycle batteries are for stuff like trolling motors, etc. not for starting engines. They are for long load cycles and are constructed differently than a starting battery. Running a starter motor for the few seconds it takes for cranking an engine is nowhere near a "deep cycle".
I tried this and I still have no crank. My batteries are brand new so I know it's not that. What else could be the issue?yellow with light blue striped colored wire adjacent to the passenger side battery in the engine compartment, near the vacuum pump that has a "squeeze-and-pull" type connection. Disconnect it, and jump the male end of the connector to the passenger side battery positive terminal as tman said. The starter should crank when you do this.
Are the wiring connections at the starter in good shape?I tried this and I still have no crank. My batteries are brand new so I know it's not that. What else could be the issue?
