ignition switch wiring diagram?
29K views 8 replies 3 participants last post by  M.L.S.C.
The rod may have broken in two........ normal problem.... you must have a tilt steering column.
I will post a picture of the tilt steering column and parts......yours is #23 see my photo link.
That is the item ......one must remember the schematic is an exploded view, things are much closer together in real life.
You will be required to remove available external covers and the st wheel, you should then see the part on the top behind the turn signal MFS. If anyone has done this personally please jump in here and help MLSC.... with directions.
I really need to write up instructions for this or at least find some......... saw it done once. No camera handy....sorry.
