Long story short:
Bought a 2004 6.0 diesel crew cab 6sp. back in February and have had issue after issue. Had turbo cleaned by professional mechanic. Thought I needed Y-pipe but that was not so. Turns out the EGR bypass was loose since the nuts had worked their way off the bolts holding it in. Same mechanic fixed this. Truck runs better, but is still not 100%. It has a Magnaflow, but you cannot hear it all the time like you should be able to. Seems like when you get in on the turbo, it cuts out the Magnaflow. Turbo still spools during this time. It also seems to cut the power when it cuts out. I am worried that something is wrong that could be damaging the motor. I was driving it today and it ran like it should..Magnaflow singing and all, but then "closed up" on the way home. Fuel filters, oil, and vacuum pump have been changed.
My question is this: What am I missing? Turbo issue? Too much air restriction? I am running out of patience. Please help me before I do something rash! :SM002:
