2011 F-250 6.2L V8 here.
I just clued in the oil temperature gauge always shows ~60% between min/max, even when the engine is obviously stone cold (like immediately after starting engine when it sat all night). I like using remote start to warm up the truck so took me a while to notice, not sure how long it's been doing this. The coolant temperature responds as expected though - gauge starts moving after 5-10 mins of driving and stays on the low side, also not towing or hauling anything heavy so I'm not too worried about anything overheating.
My first thought is a faulty oil temperature sensor? Then I remembered about a month ago I got this error code (before I noticed the oil temp gauge acting up) could it be related?
P0128: Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
Haven't seen it again after resetting, but replacing the thermostat valve has been on my to do list.
Would appreciate any insights.
(tried the search but only finding threads about oil temperatures while towing)
