Big eyebolts in the front and rear corners. Used big Nylock nuts and washers on them. I put them in the hole already in the sides of the square holes that are already there. You can hold the nuts from the top and use a screwdriver to tighten the eyebolts. Puts the tiedowns kinda high on the bedside, but it works for my dirtbikes without issues, and no holes to drill in the bed.
I bought the tie downs from 99 up. Just getting around to installing them in my new bed, after I have bedliner sprayed on. Also going to put stakepocket rings in the holes on top.
i used deck tie downs from a H-3 helicopter. it gotta be one of a kind.
I got some from Tractor Supply Company, and I am holding them in with some sheet metal screws. They had several tue down type things there and I chose what worked for me. Cost me less than $5 out of the door.
96 F350 CC/LB 4x4 ZF5 with wayyy too many mods to list!
X2
"D" rings from tractor supply bolted down. As already stated less than $5.00
