Thanks klhansen for detailing that. I guess I have seen that aux. thing but never though to wonder just what was going on with it. I guess it seemed like a good idea Ford/OEM wise when designed, But has obviously proven to be an issue in the long run (sucking air wise). Ford probably figured we all would be buying new trucks before some of these things ever had a chance to get old enough to fail. I'm at 100,000 miles these days and I dump 2 stroke oil in the tank fairly regular. Sometime a little anti gel/ fuel conditioner (not to often). I would be curious as hell to get a bore scope in there to see what things look like. Guess I won't be able to see the condition of the mixing chamber screens but it would still be interesting to see how clean or dirty the bottom of the tank is.
Traildust - I always kinda liked that setup you made there with the screens being Tee'd like that back when I first saw it. Then the more I thought about all the possibilities of clogging & presumably a big part of the Hutch Mod. being to remove (any) screens in the tank that could clog and be cause for another tank drop, I started to think I would not do it (your way). Though I can see where it's pretty unlikely they could ever get totally from floating crap & just the motion of the fuel sloshing around over the outer surface would tend to keep them free of obstructions I would think. Never the less, For me I think I am leaning towards complete elimination of screens in the tank. My latest idea is that there should be a Tee design up where we remove the mixing chamber thingy, and then have TWO steel pickup tubes (WITH V NOTCHES FILED INTO THE Tip of each) that would extend down to just slightly above the bottom of the tank just like the common Hutch mod. does by extending the single tube through the OEM pick-up foot. My idea here is that it would eliminate the OEM pickup foot completely. It would provide 2 separate pickups. And with the V notches I would think it would be close to impossible for any small piece of anything floating around in the tank to completely block off fuel supply. And it would have to be enough of (stuff) that it clogged up BOTH pickup tubes AND got wrapped around enough to block the Notches too! Any of the smaller stuff would get sucked up and get caught in the OUT OF TANK Pre Pump filter (or as I have learned from all the boys here it's really a screen because filters might create extra work for the pump by to much flow restriction). I would think this design would act as a continuous fuel tank cleaner (in a way) by bringing anything small enough to fit through the pickup tubes out to the pre- pump screen & if small enough to get by that, pushed on up to the OEM valley located filter that we can change out every 15 or 30 thousand miles.Anyone have any thoughts to shoot down that design?????? I'm sure there is something I have not considered that will be an issue. Personally, I think it's a pretty good idea/design but I would not be insulted to hear the reasons it's a bad idea. But I already thought of the "extra fittings that might suck air" possibility LOL. What else???????
