IMO I don’t really see how you can improve on the original Hutch Mod. As far as the foot, there are actually two safe- guards for screening large particles the way I see it. On my install directions the tank ends are placed on 2X4’s on the ground allowing the bottom of the tank to sway down, simulating a tank full of fuel, and then length of the pickup tube is adjusted so the nubs of the foot are in direct contact and slight pressure with bottom of tank when tightening bung threaded ring.... so no way for large particles to get past, then frame located pre pump filter (also doubling as a water separator) and then the filter in fuel bowl on top of valley, and no in-tank screens left to clog.
