As long as the lines are close to the same length it won't matter, because fluids don't compress. The only practical difference will be the pressure drop, and the IP output pressure should be significantly above the injector open pressure.
Also, you can freely interchange lines from all years and models of IDI, if you need to bring the #4 line from E-series just bring the timing ferrule along it won't hurt anything.
