I am getting tired of setting code 1211 so I am wondering what options I have. First of all, are there aftermarket injectors that require less oil and give a higher amount of flow (than stock)with the stock HPOP and not set the code? I am wondering if I can get injectors instead of a HPOP and still reap the benefits and gain the same (or close to) amount of HP? I understand you can get close to 400 hP with the HPOP(aftermarket) but will aftermarket injectors do the same with the stock HPOP?
