I have a 96 F-250 powerstroke, It isnt running the best. When i get on it, it sounds like the injectors are not spraying right. I have heard that the injector harness is probably the problem. It has 190,000 on it, just wondering how to decide if it is the harness or the injectors.
any check engine light or codes? if it idles fine its not going to be electrical and theres usually a check engine light on when somthing in unplugged or melted.
havent had a chance to check for any codes, no lights are on. Sometimes it idles fine and sometimes it doesnt. When it doesnt idle right, it will idle fine then it just starts missing, then it will start to idle fine again. It sounds like i take the connector off the injector for a few seconds and put it back on.
