There should be two little Screws that you should be able to remove to drain the oil. One is between the #1 and #3 injector and the other is between the #5 and #7 injector. you might have to lift up the valve cover gasket to see them. It will take 5 or 10 minutes to drain. will keep oil from gettin into the cylinder.
