Below are some pics of a disassembled fuel pump, most notably the screen at the suction end. It is worth noting that this stuff was largely "stuck on" pretty good. Meaning it did not just come off spraying it with carb cleaner and such. I had to scrape the screen, both sides and spray/scrape more multiple times to get it cleaned off. Also worthy to note is that in the space behind the screen there was a bunch more gunk "floating around". Not stuck to the screen, but in a position to get sucked against it and plug the spots that were flowing a little. I took the opportunity to blow into the fuel line back into the tank and perhaps clear some things from that screen/pickup also. It seemed pretty clear though
And yes.. this same fuel pump is back in operations on my truck and my fuel starvation issues appear to be alleviated (for now - till the next time I need to do this from running all kinds of "crazy fuel". (last time I did this was several years ago.).
I think is is to be expected that if you run biodiesel and W85 and/or whatever for years with sometimes questionable/substandard filtration, that if you are having fuel starvation issues, that this might be the cause. Might show up in cold (but not fuel gelling) temps also.
Also tells me that I should have a fuel pressure gauge to head this type of thing off before it causes issues on the road.
This job is not that hard (but not that easy either, you have to be careful about taking it apart and putting it back together right)
