1 - 10 of 10 Posts
Was just curious to know if any of you guys had this happen to you. Was going down the road the other day and all of a sudden it felt like you had turned my heater or maybe defroster on. But no air that I could feel was coming from the vents. I had my window down just riding around. No strange noises or smells /ubbthreads/images/graemlins/shrug.gif like something was getting hot. It puzzles me. Any thoughts?
Discussion Starter · #2 ·
This must have everyone stumped! /ubbthreads/images/graemlins/shrug.gif
did ur temp selector go to hell on ya? /ubbthreads/images/graemlins/crazy.gif that happened on my 92 i went to turn the temp back up one evening when it was cool out and all of a sudden it was a furnace in there here the selctor was all full of dust and grim and got bound up and i broke the knoob onit
To be honest nothing was different. No knobs were turned on or anything, just riding down the road and it felt hotter that usual inside the cab,,, STRANGE! /ubbthreads/images/graemlins/shrug.gif
All I can think was that the fan clutch had engaged, and it was blowing hot air in the windows....my old Chevy used to do that a lot...
I had a '94 4wd F-Super Duty (F450) that had 4 wheel discs and a drive shaft brake on the output of the transfer case, I would always forget to release that brake and be driving around slowly and the smoke would start to rise up through the transfer case shifter hole.... /ubbthreads/images/graemlins/wink.gif
Birken
I know what ya mean man my truck does same thing. I dont use my a/c very much so when its hot outside it feels almost as hot in the cab as it does outside. I cant figure it out either.
Sounds typical to me. Time for A/C Mod. Below is from Baz's tips.
AC MOD
It will stop the flow of hot water through the heater core when the AC controlls are in the MAX setting and the OFF position providing cooler temps and preventing the hot pocket of air down by you feet. I went to NAPA and asked for the 'hot water shut off valve' from a 1990 Ford Ranger with a 4.0 V-6, I also got 4 - 5/8 hose clamps, a couple feet of 1/8" vaccume line a a 1/8" plastic "T" for the vaccume line. To begin the install loosen the cap on the radiator overfill to remove pressure from the system (do this while the engine is cool). On the passenger side of the engine compartment there are 2 - 5/8" hoses that come from the firewall and continue to the engine, these are the heater hoses. Cut the hose closest to the drivers side (It does'nt really matter where, I did mine about 6 inches after the fire wall). Then holding the 'shut off valve' with the vaccume controller twards the pass side install the portion of the heater hose coming from the cab to the top left nipple on the 'shut off valve'. Tighten the clamp. Install the portion of the heater hose coming from the engine to the top right nipple and tighten the clamp. Next cut the heater hose closest to the pass side in the same location as the previous. Install the portion coming from the cab on the lower left nipple, tighten the clamp. Now install the portion going to the engine on the lower right and tighten the clamp. Measure out how much of the 1/8" vaccume line you need to reach from the bottom of the vaccume canister on the shut off valve to the white vaccume line on the pass side that goes to the vaccume operated door underneath the pass side cowl. Cut that white vaccume line and splice in the 1/8" plastic "T". Then run the 1/8" vaccume line you meassured out from that plastic "T" to the nipple on the bottom of the vaccume canister on the shut off valve. It sounds more complicated than it is. Once you do it it will seem real simple. Happy trucking!
Thanks Bryan Central Texan
AC mod helped me some...but nothing like the Dynamat /ubbthreads/images/graemlins/biggrin.gif
Look under the hood near on the a/c evaporator case. On top of the case you'll see a vacuum pod sitting on top with a hard plastic vacuum line(probably black) coming from it. The vac line goes into a wire harness under the evaporator case. That black line tends to get dry rotten and will leak vacuum allowing the blend air door to open and won't pull enough vac to open the vents. That's why it won't blow thru the vents. That's what happened to me and I was about to put a compressor on it. Check my pics for a photo of it.
1 - 10 of 10 Posts
