1 - 14 of 14 Posts
I am going to get my gauges in the mail tonight (hopefully) /ubbthreads/images/graemlins/crazy.gif and start install tomorrow morning. I got the pre-wired package from Bob and it is supposed to be ready to go. I also got the AIH delete plug with nipple. Is there anything that I need to be prepared for that will hold me up on a quick installation. I have a very busy day and have to get that done early and quickly.
If anybody has experience with bob's pre-assembled package, could you tell me how the install went? Easy I hope! /ubbthreads/images/graemlins/phoney.gif
I installed Bob's predone guage kit two days ago and I also bought the AIH delete plug with the boost kit and code eliminator.
Here are my thoughts: Bob's directions are great. Sometimes on the pictures I had to turn them to be sure the picture's orientation and my own were the same. As for the code eliminator, there was no mention in the instructions of what to do to the black wire coming from the heater. I just followed the directions and took off the wire and I have not recieved a code yet so I hope I did it correctly.
I did not ask or call but I think you can shorten the boost tube and the wire for the transmission temperature BUT NOT the wires to the pyro. I would be carefull not to run any of the wires near anything that gets hot. I bought looming and it worked great. I would loom it before installation becuase I did it after and it took a while longer and was difficult to get into some small spaces.
The pyro instructions say to drill a 1/4" hole. I did and the pyro did not fit. I was careful, slow and methodical so that I did not get any large metal pieces in the exhuast when I used the 1/4" bit to make the hole slightly larger at the edges.
To save time before you get the guages or before you install (if you won't be driving your truck after) you could go ahead a take off the factory A-frame and remove the heater and install the code eliminator if you bought it. To do this you'll have to remove the plastic Powerstroke cover that sits over the fuel filter access. You could also drill a 1/4" hole into your exhaust pipe about 2" after the transition from the manifold (be sure you know where this is before drilling or it might be better to wait for the picture (but you may know and it would save some time on the install).
I hope this helps. In all, it took me about 3-4 hours. I go very slow and am always having to look for tools, stuff, etc. You may not have the same problems. Good Luck! If you have any other questions, I can help as I am sure many others could as well.
Wow! Thanks for the info. That is super! I usually get UPS about 5pm so i think I better wait until AM to get the project started. I also want to take my time and do the job once! So it was pretty easy huh? I am kinda nervous about tapping into other wires and such. I would hate to break something because I am leaving on vacation Saturday morning and can't afford problems.
Anyway, thanks for all the information! That is super! Also, I would assume that you want to do all that work when the motor is stone cold too?
Don't worry about tapping into the wires. The directions are clear and the wires are easily accessible and the connectors make this part so simple. I had to cut off some tape from the factory looming but other than that you'll know exactly what to tap into with which wire. It's really no sweat. If you can lift your truck (I have drive up ramps but did not use them...uggh!) it will go easier becuase of space. I am not small (just short) but I fit under the truck without it being lifted and it was just a little cramped.
Cold truck=no burns==easier install. I would start early, take your time and you'll find out when it's done that it wasn't as hard as some other things you could do. I hope you love the guages. My wife even mentioned that they looked factory and she mentioned that she liked the look better with them than without!! She has never really liked a mod before.
If you get to something you need clarification for, just give Bob a call. I have bought so many things from him and called many times for clarification. He and his wife are nice and more than willing to help.
Who's Bob ? Or I should say which .
Thanks guys! I got the gauges, read the direction, started the install, and ran out of daylight. I am going to finish tomorrow morning. Pretty simple though!
Again, thanks!
Discussion Starter · #9 ·
DEFINITELY!!! Only way to go. Let Bob throw those babies together and let you have the fun of installing them. Easy!!! I am almost done with my install. I figure 1 hour tomorrow and complete!
Hey guys, is the extra money worth it (100 bucks or so) for the pre-assembled?
It depends if you want to buy a separate guage pod and possibly paint it yourself (or buy it painted) and then buy the guages and install them. It would save you money to do all of it yourself but I bought the preassembled kit to save effort and time, not money. I did, however, want to be sure that each of the connections were done properly and with care so I did that part myself instead of having a shop do all of the work for me.
It just depends on the effort vs. cost scenario that you prefer...
Buying something pre-assembled doesn't always ensure that connections are done properly. I'd rather take the time myself and ensure all wire connections are done tight, and fitment is perfect, then worry about whether a person did the right job in the back room who had multiple guage clusters to assemble and therefore raced through them to get the job done.
Hammer
Hammer
I cannot argue; I guess I was taking a chance with that part...
/ubbthreads/images/graemlins/shrug.gif
This may seem wierd but..are all the gauges wired for lighting ??
I don't really need the lighting aspect as I don't drive at night so hence to and therefore...
It would seem like a tranny temp gauge without lighting wouldn't cost too much and be an easy hook up, right ??
Thanks.. /ubbthreads/images/graemlins/phoney.gif
1 - 14 of 14 Posts
