1 - 11 of 11 Posts
How are you guys installing you satellite antennas? I ran mine through the third brake light, but now I am a little worried about it leaking. I pulled the gasket out of the light and ran the antenna through it and glued the gasket back to the light. I then cut a little groove in the light for the wire. I then finished it up with a little dab of sealer and used the black cover that is use to hide the wire. I ran this over the roof and down on top of the light, so it is covering the wire. I have a paper thin gap between the light and the truck. I am not sure if it was flush before or not. I did have to clean alot of dust out of it, which makes me think it was letting dirt in before. Do you think it will leak? I was going to take it back apart tomorrow and use some black strips of rubber sealer I have.
I used 1/4" weather strip(the kind you get for home windows at home depot)to avoid any chance of leaks. It worked great no leaks almost 2 years now /ubbthreads/images/graemlins/biggrin.gif See pic here
I put mine behind the plastic cowl. Took all of 10 minutes and I've never had any degradation in signal strength.
Hidden XM Antenna Clicky
I have my XM antenna, CB, and Fire Dept./EMS/Ham antenna wires (3 in total) running through the 3rd brake light. Never had a leak yet, in over 4 years of use. Also, for a week or two, I had the XM antenna mounted on the dash until I had time to install it on the roof. Since moving it to the roof I haven't noticed any better reception. I should have just left it on the dash. When I installed XM in the GF's Expedition, I put the XM antenna on the dash and she never has any reception problems.
Roger
Thanks for the info guys.
Depending on the antenna size you have you might try the center running light on the cab.
That's what I'm going to try when I get my truck back from the shop, just eliminate the bulb and run the wire around the edge of the head liner.
JeepPuller: nice hidden idea!
James
I have mine INSIDE the cab. I have the XM "mini" antenna that came with the Roady2. It sits right on the dash at the bottom of the driver side a-pillar and never loses signal....and never leaks.
1 - 11 of 11 Posts
