I recently tried to install an alarm/ start system on my truck. I had a few problems so I took it to an installer. After having it installed my Instument cluster started acting up. It would turn on and off while driving. I opened the hood and seen that the negative battery posts were loose and one was off and had arced a few times. After securing them I found that the intrument cluster only had the temp gauges and the tach guage would randomly turn off and on with the check gauge light and check engine light.
I took the truck back to the installer and he re-checked his wiring and said everything is wired right. He thought I may have damaged something when I tried my install at first.
Anyways I checked and cleaned the battery posts, checked his grounds he did. My cheaper code reader pulled no codes.
When the guages turn off and on I hear a click from the instument panel.
Any help is appreciated
