1 - 15 of 15 Posts
Could somebody inform me on how tight the intercooler boot clamp are supposed to be. /ubbthreads/images/graemlins/shrug.gif thanks
Mine are as tight as they will go just shy of them snapping off. /ubbthreads/images/graemlins/wink.gif
Tough call. I imagine that there is a torque spec somewhere. Do you have a "Repair manual" with spec.s? Might be able to find one online.
Quote from Grumpy Jenkins, "Tighten it till it strips, then back it off a 1/4 turn"... /ubbthreads/images/graemlins/grin.gif
I thought it was tighten it until it snaps off and then back it off a 1/4 turn. /ubbthreads/images/graemlins/biggrin.gif.
Honestly I have not had a problem with mine and they are cranked down pretty good.
I agree wrench good'in tight!!!
Have a spare clamp so you can know how tight failure point is, then tighten the next one almost that tight. Test to destruction.
As i always say, PFT!!!! Pretty Fricken Tight
If you have a heart condition, do your self a favor, use the tighten until it breaks then back off 1/4 turn. these things when they pop off make quite a sound.
I second what MrPlow said, it is a sound you wont like, and you will know what it is right away.
I remember where I was everytime (4 times) its happened.
Each time I was like OH NO! another turbo! Then about 20 seconds later come to my senses, Pull over, pull out the ratchett/socket and extensions from the mapholder in the door and put them back on.
Usually still shaking when the job is done.
These look pretty beefy. Note the clamps keeping the CAC tubes from separating.
Nice motor.
Yeah. That's Sapps motor with the infamous Tymar rods.
[/ QUOTE ]Depends on the clamp. The t-bolt style without constant torque are supposed to be tightened to 80 in-lbs! The constant torque style with the spring in the clamp will not expand or contract as designed if over tightened. They are supposed to be tightened to 75 in-lbs! So good and tight is too tight if the spring is compressed all the way.
1 - 15 of 15 Posts
