Hey Guys would appreciate any suggestions on 2008 F250 6.4 with SCT LiveWire running offroad hot street tune. I am having an intermittent problem about once a day where I have zero throttle input- truck will only idle. If I shut her down and restart the problem goes away most of the time.
Trouble codes per the tuner:
P174E- output shaft speed/ABS wheel speed correlation.
P0703- Brake switch B input circuit
V0101- Lost communication with TCM
P0000- haven't found this code
When this problem occurs the truck starts and idles perfect just won't go anywhere. Would the TCM communication problem be the most likely culprit and what could be the cause?
Thanks in advance,
Rick
Thanks in advance,
Rick
