Hi folks:
My '96 with the E4OD tranny has an intermittent no start. I've discovered that when this happens there is no voltage on the line to the coil of the relay on the fender. This points to either the neutral safety switch or the ignition switch or the wiring in that direction. (The glow plug relay does trip so I don't think there is a mechanical problem with the ignition switch.) Is there an easy way to narrow this down without just replacing parts? I Really Don't Want to have to get into the steering column to do that switch.
And a bonus question: How painful is it to do the neutral safety switch? If the recovery requires not more than one beer I'd do it myself. Otherwise I've got other things to do with my time.
THANKS!!
THANKS!!
