Having a intermittent problem that's driving me nuts. Its happened 3-4x in about 3 months. Its always a cold motor issue. Truck starts fine, fires right up. I usually warm it till about 170° before driving. Right about the 120-150° range the idle drops, gets really rough, almost lopping. Zero power. Truck won't even move under its power. Black smoke when throttle is applied. But once it hits 180ish°, shut it off and restart it and its totally fine.
The other day it wouldn't start, killed the batts trying. It would almost catch, than stumble. Finally got it started, but it was right into its rough idle mode until warm, cycle the motor and no problems.
170k
Studded and deleted
Ficm 47-47.5 will show 46.5 for a split second
Hoop is 700-800 at idle
Fresh motorcraft filters
Amoil
Archoil
Twc3
Batts are fine, load test OK
Ideas? What to look for?
ICP sensor?
Ficm shorting some how but still at 47v?
170k
Studded and deleted
Amoil
Archoil
Twc3
ICP sensor?
