Been dealing with a no start issue for a week or so and finally got some time to try and change out my ipr valve. I got the old valve out but the screen stayed in the bore in the hpop. Any ideas on how I might get it out. I tried to put the valve back in that it might stick and come loose but that didn't work and I tried some using some pics but no luck yet. Do you think if I just crank the engine for a second the oil pressure would blow it out? Any advice would be great. Thanks.
Discussion Starter · #2 ·
I kept at it with a small pic and was able to get it turned sideways and I fished it out with a pair of needle nose pliers. It did have some gunk built up on the screen. Once I got the ipr changed out and everything hooked back up the truck started right up. Idle is a little erratic right now but I'm hoping once I run it some more it will straighten out.
Anytime you open the HPO system it takes 20 minutes or so of running to purge the air out.
