Need to know what could be causing irregular & irratic idle on 03 6.0. /ubbthreads/images/graemlins/shrug.gif
After driving for approx. 1/2 hour when you start stopping at stop lights/signs the turbo quits whistling and it sounds like it is under a load. The RPMS go from around 650 to 626, back up to 650 then drops to 570 then it goes back up. Sometimes it sounds like it wants to die. The boost on the turbo goes up and down also when all of this is happening. Power and shifting all are great once you get going again. Could this be an EGR problem, or maybe an injector problem?
