1 - 11 of 11 Posts
When driving at about 65-70 mph i run about 1800-2100 rpm but sometimes when going up steep inclines the cruise will drop the trans into 3rd gear and the rpms skyrocket to 3000+ rpm. Always catches me off guard and scares the sht out of me. Is this something I should be worried about?
· Super Moderator
Unless you have aftermarket programming or a chip in the PCM there is a govoner that will kick in around 3400 RPM's if I remember right and you can hold the engine speed right at that point for as long as you want with no problems
Im definitely curious if there is a rev limiter. But rev-ing over 2800 just sounds scary to me but im sure its fine. Maby one day ill feel brave and floor it to see if there is a limit
· Super Moderator
I hit it right after I bought my truck. I dropped it out of fifth gear and hit fourth while passing a truck on a two lane truck.
When it hit the limiter I about crapped my pants and thought that I had smoked the engine.
Never again
· Administrator
One of the Ford-approved tests (I think for oil aeration) is to hold the accelerator to the floor for 2 minutes in neutral.
:oops:
Never again
Yay that’s exactly what it did to me the first time it happened. Scared the absolute sht out of me.
Early 1999 f350 cc, srw, 4x4. Pretty much stock no gauges.
Mine is a 99. In 99 it downshifting while pulling a 5th wheel camper up an incline and I thought a fighter jet was landing beside me it sounded so loud. Got home and called Diablo Power Chips. The tech told me under a load like that it could possibly shear the water pump shaft with a downshift like that (not sure if that's true or not) but I ordered a chip and haven't had that problem again.
Discussion Starter · #10 ·
[/QUOTE performance chips do help but they do sky rocket egts. If you dont have a egt gauge I recommend getting one. Glow shift makes a 3-1 digital gauge that has egt , boost and a trans temp sensor. I really like it as it dosent take up much space and it looks stock
I pull a fiver RV with F250. When going up inclines, especially LONG ones, i turn cruise control off, use foot control. I drive like egg between foot and gas petal. I noticed when doing long climbs, boost increases, with oil, water and tranny fluid temperatures increases. Not to mention the extra load imposed on the engine bearings. I found I could slow down, watch temperatures while going uphill, seek a speed where HH fluid temperatures do rise, seek stability of temperature at a reasonable towing speed.
Know of other owners who use cruise control while towing, let er rip going uphill, and suffered blown engine. I can afford to slow down, but not a blown engine. Especially if truck is a 2011 model, with many of the known faults by Ford at play.
1 - 11 of 11 Posts
